LYE Zhongneng Engine oil Purifier
Application:
LYE series oil filter machines cannot only remove the carbon particles, deep oxides, etc., but also can filter off the harmful matters such as colloid, bitumen. After treated by the machines, the quality indexes are improved also, so as to resume the performance of engine oil, keep the engine being lubricated, guarantee lubricating system of engine to work properly and prolong service life of engine oil. The series machines are special for recycling kinds of engine oil used in ships, cars and other vehicles.
Features:
1. Fine precision filtering material, with excellent mechanical strength and long service life, which is anti-erosion and anti-hi-temperature, with high performance of removing fine particles in the contaminated oil.
2. Completely removing water content and harmful gases from the contaminated oil.
3. Manually/automatically removing residual impurities from the machine, which is easy to operate and on the safe side.
4. The mixture of gases drawn out via vacuum system is condensed and dewatered by forced air, which improves the effective output power of the machine and prolongs the service life of vacuum pump.
