585,761 active members*
4,129 visitors online*
Results 1 to 7 of 7
    Jul 2005
    261
    Hire a machine shop to make surface plates
    I am looking for a machine shop to do some machining on steel. Squaring, surface milling, etc...
    I'm re/designing my garage-made cnc machine, each axis at a time. In the past, I would do this work myself, but now I feel I want these structures made from steel, and I do not have the equipment to do this work on pieces. I feel the basic square plate designs with bolt patterns would be simple and easy for someone who had the right machinery.
    Sizes are roughly 24" x 30" x 1" for part #1 and 12" x 16" x 1" for part #2)
    Basically, these would be the plates that I bolt my linear rails and ballscrews to. A plate on the bottom and plate on the top. I would create a mechanical drawing.
    So I was wondering if anyone had advice for shops I can call for some quotes, or links to websites? Any input on their experiences and what to lookout for?
    WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
    Apr 2007
    1955
    There is an rfq section in this forum.
    Mar 2004
    1661
    I moved it.
    Feb 2012
    To whom it may concern,
    MJ-machining is a newly found machine shop in the Pottstown Pennsylvania area. If you are in need of machining services, please feel free to send us an email with a blueprint and part quantity for a free quote. We look forward to doing business with you in the near future.
    Thank you,
    Matthew Miklich
    Josh Evans
    MJ-Machining.com
    Jan 2006
    2985
    Any kind of big parts like this, you are going to want a local supplier as freight will kill you. If you aren't aware of a machine shop with the capability you need, ask a shop you know of. Around here all the smaller guys know who has what equipment as they turn to them when they need the bigger stuff done.
    I'm not sure what accuracy you looking for but I'd think you need a stress relieved and blanchard ground plate to make a good machine base. I'm not sure what you plan to cut but a chunk of MIC-6 might alleviate some of the hassle.
    Matt
    May 2007
    119
    Matt that was great advice but that post was from 2007 lol that is something I would do
    Jan 2006
    2985
    I only saw the last post was recent, didn't realize it was just random SPAM.
    Always a day late...
    Matt
  1. Use Machine Shop vs. Buying Machine
    By imp22b in forum MetalWork Discussion
    Last Post: 06-06-2007, 12:33 PM
  2. Man Vs Machine (Do You recon you could make one?)
    By ynneb in forum Community Club House
    Last Post: 06-01-2007, 01:00 AM
  3. what machine would I need to make this cut?
    By steve knight in forum Commercial CNC Wood Routers
    Last Post: 08-12-2006, 09:30 PM
  4. Experienced CNC Machinist, Programmer, and designer... Services for hire
    By Steeda31505 in forum Employment Opportunity
    Last Post: 05-10-2006, 09:18 PM
  5. How to make Parallel Square Beam/pipe without flat surface ?
    By Calico in forum Welding Brazing Soldering Sealing
    Last Post: 06-27-2005, 02:13 AM
