585,599 active members*
3,453 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Emcotronic driver board failure
    Jul 2007
    17
    Hi
    I have a Emco vmc100, with emcotronic control and finding the stepper motor drive boards keep braking down, is this a common problem with these old machines, or have I just ended up with a bad one.
    What would be the normal causes of these boards to break down?
    One minute the machine seems to work fine, but then next time you use it, a board pops, these things are not cheap! Ouch!
    I was wondering if the boards are easily repairable, by maybe soldering some new replacement components on them.
    I must add that I don't know too much about electronics, but I am very practical minded and any guidance/ info would be greatly received.
    Or the other option it to retro fit a PC based stepper motor driver control and ditch the emcotronic, but I have not come across one which makes use of tool changers.
    Any help would be appreciated
    Adee
    Jul 2007
    17
    Hi If anyone reading the post above has the same problems, I may be able to help, got mine sorted and leant a lot.
    you can email me direct at [email protected]
    Adee
  1. Need Emcotronic code
    By smoregrava in forum Controller & Computer Solutions
    Last Post: 01-04-2021, 07:27 PM
  2. Emcotronic M1 all you need to know
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2017, 12:38 PM
  3. 1993 VF2 Magnetek Spindle Driver Failure
    By gar in forum Haas Mills
    Last Post: 11-20-2014, 08:20 PM
  4. single axis driver and a b.o.b.,or multi-axis driver board
    By .xXACEXx. in forum Stepper Motors / Drives
    Last Post: 07-03-2007, 05:13 AM
  5. New and need your help Please (driver board)
    By Oldmanandhistoy in forum CNC Machine Related Electronics
    Last Post: 06-12-2005, 10:48 PM
