586,000 active members*
4,834 visitors online*
Results 1 to 7 of 7
    Jan 2007
    14
    Loosing steps
    I have just finnished my first cnc router and everything works fine (almost). Last night I was makeing a puzzle for my kid. I was routing in 6mm ply an suddenly I noticed that the X-axis was about 5mm off (minus).
    I have read a lot of posts on the zone about loosing steps, but I have not found an answer to why this happends.
    I notice if I turn up the velocity the motors are making sound but stops. Likewise if I turn down the accelleration (very low) the motors accellerate and suddenly stops, but they are making sound.
    Can anyone tell me what is the proper figures for my setup?
    Some data:
    Hardware: http://www.kelinginc.net/ThreeXCNCPackage2.html
    Leadscrew: 1.75mm
    Microstep: 1/4
    Amps on controller: 3A
    Units: mm
    Best regards
    Terje
    Mar 2005
    59
    Hello!
    You should change step and dir pulse to 5, I think that would help you!
    Accelleration will be fine (50mm/sec), step/mm is correctly 457,14
    Apr 2006
    3498
    Please if somebody tell me if the speed(IPM) can be increased by changing the step and dir values in Mach3. what effects can we get by changing these values setting from 0-5. please explain
    Quote Originally Posted by Khalid View Post
    No, the speed won't change. Those numbers specify the duration of the step and direction pulses. Some drives need higher numbers to work correctly.
    If you lower the accel and are still losing steps, you'll need to lower the velocity as well. Most likely you're exceeding the limits of your machine. There are a couple things you can do to increase top speed.
    Increase the voltage to the steppers. If your drives can handle it, increasing the voltage will give you a proportional speed increase.
    Change to higher lead screws or gear them so the motors turn slower. Steppers have more torque at lower rpm's, so changing screws can increase your speed up to double in some cases.
    It's possible that you're experiancing resonance. If so, this thread may give you some help.
    http://www.cnczone.com/forums/showth...639#post256639
    Jan 2007
    14
    Smile
    I did what Juka wrote. I changed the step and dir pulse to 5.
    I did a testcut of 138 circles (see attached file). The code contained 26000 lines and the cut was finished after 1,5 h. Success:banana:
    I used a v-bit at 1.5 mm depth, so the cut did not stress the motors. Maybe I will loose steps when I begin to carve deeper?
    I must ask the same as Khalid: What did I do?
    Regards
    Terje
    Attached Files Attached Files
    Jan 2007
    14
    Ger21
    I read the post about resonance and damping. That was some interesting reading. I fond my problem in post #45. The video shows exactly the same problem I am facing.
    I ran down to my workshop and made a flywheel out of wood and a role of tape. (just to test the concept).
    I tested without flywheel, and when I reached a velocity of 690mm/min the motor stalled. I mounted the flywheel and started to increase the velocity. When I reached 1800 mm/min I did not want to go any further because my flywheel wasn’t balanced well enough. (the whole gantry was shaking) I think I have to make a real damper so I can speed up my router.
    Terje
    Apr 2006
    3498
    My Dear Ger21
    Thank U For Ur Kind Information
  1. loosing Radius
    By frästkle in forum EdgeCam
    Last Post: 03-21-2008, 05:42 PM
  2. loosing steps at slowr speeds?
    By bearwen in forum Mach Mill
    Last Post: 10-20-2007, 04:04 AM
  3. Loosing Steps How to Check
    By Cartierusm in forum Mach Software (ArtSoft software)
    Last Post: 09-11-2007, 12:26 PM
  4. Loosing A Friend
    By jackson in forum MetalWork Discussion
    Last Post: 02-17-2007, 06:02 PM
  5. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
