Just an update.....
Ordered the following items from the UK in preparation to building the 25" x 37" table:
1) All the aluminium material from Droitwich Aluminium, and was cut to size, accurately FOC. Great help!
2) Skate bearings (ABEC 7) from VXB via Ebay
3) All the Beech wood blanks from Woodstock of Telford
4) All the stainless steel tubing grade 304 in direct replacement for the EMT tubing as stated in the plan from another ebay supplier. The tubing was cut to length FOC. Tubing OD was 26mm and 21mm for the 3/4" & 1/2" EMT respectively.
5) All the nuts/bolts/washers from Coronhust of Cannock
6) The pulleys and belts from SDP as reccomended in the plans.
7) Yet to get the 3/4" MDF for the table base from a local DIY store.
8) The stainless steel M8 & M6 all-thread rods via a supplier on Ebay.
9)The stepper motors from an Ebay supplier.
10) Stepper motor driver kits from Aaron Garber in the states.
So good to go soon and look forward to having time to play...... Will post some photos soon when there is something worth viewing.
Kindest regards, John R.
