Originally Posted by
UKRobotics
Another question on the same subject .. the motor in my machine is a 400v DC series/shunt wound motor. Is it possible to reverse the motor direction by swapping the polarity of the field voltage or will this only work with the armature?
If I can get away with the former that is much lower voltage and current so I could get away with cheap relays rather than vastly expensive contactors.
The direction can be changed by swapping the field if need be, in series mode or shunt, I assume it is use in shunt mode?
Al.
Albert E.
