585,754 active members*
3,853 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > MAXNC 10 with nema 17 stepper motors and Sainsmart Prover GRBL contoller
Results 1 to 6 of 6
    My friend gave me an old MAXNC 10 and I've retrofitted some small nema 17 steppers and a Sainsmart prover grbl controller.
    I'm trying to get the stepper motors calibrated and I really have no idea what i'm doing.
    I've tried changing the values for $100, $101, and $102. but I don't fully understand what i'm doing.
    my stepper motors have a 1.8 step angle
    leadscrews are 1/4-20 allthread
    What values should i be changing?
    Thank you in advance
    707
    Apr 2004
    5735
    Re: MAXNC 10 with nema 17 stepper motors and Sainsmart Prover GRBL contoller
    You should be changing the motors. NEMA 17 steppers won't have enough torque to run that machine. All the MaxNCs were originally equipped with NEMA 23s; I'd suggest looking for some of those, or if they came with it, finding a controller to run them (not sure if the grbl is up to it).
    Andrew Werby
    Website
    Quote Originally Posted by awerby View Post
    Thank you, i agree this is not the ideal controller or steppers. I'm trying to learn how to get this machine running as I've got a Harbor freight Central machinery 44142 mill/drill/lathe i would like to convert to cnc when i'm done with this machine.
    I must be doing something wrong. If i set my $100, $101 and $102 values to 3000 it gives me about .98" movement when jogging the machine one inch.
    When i use the formulas to calculate these values I come up with a $100, $101 and $102 value of 1259.84252. that value gives me about .38" movement when jogging the machine 1 inch.
    I will be going out to the garage momentarily to test these values again
    Apr 2004
    5735
    "I must be doing something wrong. If i set my $100, $101 and $102 values to 3000 it gives me about .98" movement when jogging the machine one inch."
    That's probably as accurate as you're going to get. One problem with that machine is that the screws are directly coupled to the motor shafts and float with the motor armature, which isn't rigidly constrained - there's no bearing fixing them in place. So if they're .02" out, that's totally understandable.
    Andrew Werby
    Website
    Jul 2018
    6323
    Hi 707 - Due to mechanical and electronic issues as Awerby says the theoretical value and real value are never the same. So you do the motion and measurement a couple of times and if commanded 1" is actually 0.98" then you multiply the 1259.84 value by 1/0.98 to give 1285.55 to correct the difference. Each axis will be slightly different so you calibrate each separately. So update the value, redo the test and maybe correct again to get it as close as poss to correct. Use as big a distance that you can measure accurately with as well. Say 125mm on a 150mm vernier...or imperial if thats what you have...Peter
    Mar 2015
    409
    You could have measured some backlash in your result. Move 1", zero the dial and than move another 1" in the same direction. Repeat the last step and gather some measurements. It will tell something about the steps/inch and the repeatability.
    200 steps/stepper revolution, 20 TPI leadscrew you need 200x20=4000 full steps/inch. According to your 1259.84 value, you use a micro stepping of 8. Your 3000 steps/mm setting seems pretty much OK (0.98") so there must be something wrong.
    You can turn the leadscrew by hand (20 turns) and check the movement.
    You can set GRBL to report in inches, but you have to setup grbl in mm settings.
    My assumptions are based on that you use a grbl version 0.9 or higher.
    https://diymachining.com/grbl-settin...-how-to-guide/
  1. Replies: 4
    Last Post: 01-12-2023, 01:55 PM
  2. Stepper Motors not working on new Sainsmart MX3 3018
    By zlens41 in forum Machines running Mach Software
    Last Post: 01-13-2020, 01:55 PM
  3. Sainsmart 3018 Pro using Grbl
    By portanav in forum CamSoft Products
    Last Post: 07-30-2019, 04:10 PM
  4. Nema 23 stepper motors
    By nenetwork in forum Stepper Motors / Drives
    Last Post: 04-24-2009, 06:46 PM
