Hi, I've acquired a Bridgeport MDI Series1 with a TNC 150 control. When I run a program with a Label call repeat it will occasionally completely skip a linear positioning block and then go to the wrong position in absolute mode. It will then display an error message saying it can not complete the next block. This is because it knows it's gone to the wrong position. It's already run through the code once to get there and I've tried turning cutter comp on and off.
Any suggestions as to what to look at?
Alan
