585,668 active members*
4,312 visitors online*
    Jan 2006
    40
    TNC 150 skipping blocks intermittantly
    Hi, I've acquired a Bridgeport MDI Series1 with a TNC 150 control. When I run a program with a Label call repeat it will occasionally completely skip a linear positioning block and then go to the wrong position in absolute mode. It will then display an error message saying it can not complete the next block. This is because it knows it's gone to the wrong position. It's already run through the code once to get there and I've tried turning cutter comp on and off.
    Any suggestions as to what to look at?
    Alan
    Jan 2006
    40
    Re: TNC 150 skipping blocks intermittantly
    Sorted. Put the line in twice and it works for some reason, no idea why.
    Jan 2013
    474
    Quote Originally Posted by Alan B View Post
    Must be a glitch, subroutine calls should return to the line after the call. In writing it twice you have ensured the line call isn't missed. Strange one though.
  1. Heidenhain TNC 150 Post?
    By maxvic in forum Post Processor Files
    Last Post: 05-16-2014, 02:20 AM
  2. tnc 145/150 swap
    By Mike Woo in forum Bridgeport / Hardinge Mills
    Last Post: 05-21-2011, 12:11 PM
  3. heidenain tnc 150 / 2500
    By kennyayr in forum Bridgeport / Hardinge Mills
    Last Post: 11-25-2009, 06:15 AM
  4. 4 axis on TNC 150?
    By spock in forum Bridgeport / Hardinge Mills
    Last Post: 07-14-2009, 05:46 PM
  5. Tnc 150
    By chris_bean in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2007, 05:17 PM
