I know jut enough to be dangerous when it comes to electronics and need a guide for dummies on this.
I am using OPB830W11Z slotted photo optical sensors for homing my CNC. https://www.digikey.com/en/products/...30W11Z/1637175 Been using them for almost 10 year. Now that I'm switching my controller to a Mach3Bob (MB3 with ESS) I need to relearn a few things. I can't tell if they are NPN or PNP which is kind of important for how I connect them to the MB3. I'm sure trial and error would work but I'd rather do it right the first time. I still get confused on which is which and which means normally open and closed. Again I need a for dummies guide
Also on my current setup I have to use small break out boards for these sensors to then connect to the main controller board. Do I need separate BOBs for the MB3? I don't think I do but again want to make sure.
Thank you in advance.
