585,991 active members*
5,168 visitors online*
    Sep 2018
    14
    Homing and gantry square issues
    I have found a rather serious set of problems related to homing and gantry squaring issues:
    - If the gantry squaring is stopped in any other way than normal script execution, the master/slave axis are left set as U and V.
    - If the V axis reaches first the homing limit switch, an error is triggered.
    These issues existed, as far as I can tell, since I have first used the MK3 board, but they have bothered me too much now that I have upgraded to the latest version (dated few days ago!).
    Sep 2018
    14
    Re: Homing and gantry square issues
    Please ignore the issue with V axis switch getting triggered first, it was a broken wire!
    Jan 2013
    474
    Quote Originally Posted by RaraAvis View Post
    Did you ever try switching either the switch inputs and or the motor inputs for U and V.
    I have read that sometimes the connections are mislabeled. Logically, if the switches cross-checked the master slave motors it may have been beneficial (or not).
    Sep 2018
    14
    The actual gantry squaring is working as expected. Just that if I stop the process (E-Stop) due to whatever reason, the settings are messed up and I have to manually go to File->Settings and re-assign the two Y axis steppers. With the V axis reaching first, it was an electrical problem - as per my second message.
  1. Castaly gantry out of square..
    By adam_m in forum Commercial CNC Wood Routers
    Last Post: 07-25-2020, 09:49 PM
  2. Gantry Square
    By cedric087 in forum PlanetCNC
    Last Post: 11-20-2019, 08:37 AM
  3. Gantry out of Square
    By meilcowski in forum FineLine Automation
    Last Post: 02-26-2018, 05:37 PM
  4. is there an easy way to square a gantry?
    By 15mgtar in forum DIY CNC Router Table Machines
    Last Post: 06-21-2010, 06:40 PM
  5. Method to square a Gantry?
    By Motivator-1 in forum DIY CNC Router Table Machines
    Last Post: 02-20-2007, 02:30 AM
