585,996 active members*
4,544 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > BMC 20 MAX 32 Bootsector utility
    Apr 2009
    Post BMC 20 MAX 32 Bootsector utility
    I have an old BMC 20 the machine is running great but my drive has a bunch of bad sectors and i want to make myself a replacement. I tried to clone my current drive but the bad sectors keep making the cloning software have errors. I have the drive ready with the executive_1 and part_progs partitions. I copied all the files also. I don't think i have the right utility for the boot sector. I tried to copy the boot sector and that didn't work either. The utility i have i downloaded from internet and it is the bootsrtp .bin file. When i load it it says its successful but the machine would not boot. I put my drive into an old pc and i am using the floppy emulator to load the dos utility's. Does anyone have the correct dos disk files to load the boot loader on my replacement drive. I am using the exact same drive 210mb that is currently in my machine. I might even switch to a compact flash and ditch the hard drive totally. The disk i am using is called hurco fs utility And i think that might be wrong. Does anyone have an image file i could get even? I have floppy's in the cabinet but they are for the factory software that has since been upgraded.
    Thank You for any suggestions
    Jul 2015
    Re: BMC 20 MAX 32 Bootsector utility
    Hello,
    i have the same problem. Any news? Do you find a utility disk?
  1. BMC 40 MAX 2 no keyboard response
    By jp41558 in forum HURCO
    Last Post: 02-09-2011, 01:54 AM
  2. BMC 50 Max 3 w/386 motherboard
    Last Post: 11-10-2010, 08:10 AM
  3. BMC 20 Max II resetting leadscrew map
    By thespindoc in forum HURCO
    Last Post: 10-27-2009, 04:58 AM
  4. BMC-20 w/Max II drip feed......
    By GPena in forum HURCO
    Last Post: 10-31-2007, 06:37 PM
