585,951 active members*
4,266 visitors online*
Results 1 to 3 of 3
    Feb 2023
    Fine tuning a metal business card
    I'm trying to fine tune a metal business card. I'm engraving with an Omtech Polar 50W laser, which is a 50W carbon laser machine.
    When engraving, the lettering appears to have "ghosting" or embossing around it, which I think means the engraver the lettering with too much heat. Also, it's not filling the lettering evenly.
    I'm not sure what to do from here to fine tune it. I'm at 350 mm/s and 20% max power with 15% min power. I've played around with the settings from there but I only have so many metal cards to test and my results aren't differing too much. The DPI of the text is at 396. I haven't messed with any other settings other than to set the exact the card, which is 1.1mm.
    Below is a photo. Ignore the text on the bottom side.
    Feb 2023
    Re: Fine tuning a metal business card
    Sorry for some reason the image didn't upload in the first post. Here it is
    Apr 2018
    133
    If the attachment above does not show an image for you, click this link instead:
    https://en.industryarena.com/forum/a...3&d=1677607707
    I don't have a better practical solution to this issue.
