585,997 active members*
4,974 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Cincinnati Cintimatic Vertical Bed Mill
    Feb 2023
    Cincinnati CNC Vertical Mill. Retrofit from NC to CNC. 10 Hp 230V (1ph. Or 3ph.)6,000 rpm, grease bearing spindle. Air chuck with Cat 40 taper. Table 41”x25”, X-42”, Y-21”,Z-18”. Glentek Servos, Baldor Drive, Motor, Brake. Control Solutions Inc. Control systems. Flood coolant system with pump. ( internal sump in base is 25 gallon capacity) 20 cat 40 end mill holders included. I’ve had this mill for 15 years, never any problems, used for hobby. It’s hooked up and running if you need to test it. Thanks.
    Feb 2023
    Cincinnati Cintimatic Vertical Mill Price
    Newbie forgot to post a price and location. Sorry.
    It’s $5,000 obo. Casper, Wyoming. Thanks
  1. Smaller milling machines Bed mill vs plano/fixed gantry mill
    By nilrods in forum Drilling- and Milling Machines
    Last Post: 12-17-2015, 10:34 PM
  2. Vertical Bed CNC Router
    By SimplyDifferent in forum DIY CNC Router Table Machines
    Last Post: 11-29-2011, 06:01 PM
  3. knee mill vs bed mill, brimingham, enco, jet other
    By allenpnx in forum Knee Vertical Mills
    Last Post: 12-19-2007, 03:56 AM
  4. Cincinnati Vertical Mill #3 manual or info?
    By DennisCNC in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2006, 05:28 AM
