Just got a NZ100 VFD and a 0.8kw water cooled spindle for the past week been trying to set it up with no luck
keeps giving an error of over current i attach a video and VFD Manual
what sort of motor are to trying to run? If its a 400Hz 24000rpm type, then you are risking blowing both the VFD and the spindle if you keep trying to run it WITHOUT making the correct settings in the VFD.
The default settings as the VFD leaves the factory is for a 50Hz motor. See P105. Note also that the VFD will apply maximum voltage to the motor at 50 Hz, see P110. If you have not changed those two at least to 400Hz, and assuming your
spindle is 400Hz, then that will cause an overcurrent event right there.
Craig
yes it is a 400hz 24000rpm i have set P105 and P110 to 400
did you make those settings BEFORE you tried running the motor or AFTER?
Craig
i have set it all before i attempted to run the motor
i even got a cheap second vfd to test is doing exactly the same im sure there is some settings i am missing i have been on this for days now im pulling my hair out
that's good news. Often the VFD will damage itself if those absolutely basics settings are not made initially.
I have always used Delta VFD's and while I might have tried to blow them up I've never actually succeeded. I'm not sure what to recommend now. I have inductors and resistors I can hook
up to simulate the impedance of motor windings and a high voltage differential oscilloscope probe....but in absence of that sort of test gear there is little I can recommend.
Perhaps matec has some other ideas.
Craig
Thank you i dont know what to do i feel like giving up on the hobby all together.
who is Matec?
what about P215? Have you changed that to 400Hz? In fact there are a few settings P212,P213 and P215 which look like they need to be set also.
Craig
any cursory search of the forum and you will find his posts, he is particularly good at sorting out various makes and models of VFDs.who is Matec?
Craig
P212 = 3000
P213 = 2
P215 = 400
I can't understand why P212 is range limited to 6000rpm?. Your spindle should o 24000 rpm...so I can't see how P212 will ever be right.
Craig
Thats a number that is used for the HY VFD Drive the termination of 8x3000 is not anything meaningful even if it works with this number of 3000 this is not how it normally works.
It seems you have most of the Parameters set, this is what you should have, there may be some others if this does not get you going. if you have set any others then do a Reset and set just these Parameters
P100=400
P104=0
P105=400
P106=120
P107=6 (Adjustable)
P108=6 (Adjustable)
P109=220 (Spindle Motor Voltage)
P110=400
P115=8
P202=10
P203=10
P209=220
P210= (Spindle Motor Amps)
P212= (Spindle Max RPM)
P213=2
P215=400
I will add some more Parameters, set these first, is your spindle Air Cooled or water Cooled??
Mactec54
What was the error, this is important, that sounds like you don't have it wired correctly, or you have a wiring shorting in the plug.
The correct wiring is with a 4-wire Shielded Cable from the VFD Drive to the Spindle
U / Pin1
V / Pin2
W / Pin3
Ground / Earth to Pin 4
Shield Termination is by clamping in the Plug Restraint, and a Clamp to the Ground Plane at the VFD Drive end.
For testing the spindle Plug Pins
With no Power connected
Spindle Plug ohm measurement.
Pin1 to Pin2=
Pin2 to Pin3=
Pin3 to Pin1=
Pin4 should have continuity to the Spindle Body if not this will have to be corrected, as some are not connected inside.
Mactec54
That Type of Plug is not suitable for Your spindle, you should not listen to unqualified People that do not know what is required.
You need the same type of AV Plug or can be direct wired using a special type of Cable Restraint that is suitable for use with Shielded cable.
The snips are for a cable Gland Restraint for use with a Shielded Cable, this is for direct wiring, and much better than any type of plug.
First you will have to have your spindle motor tested in case your numbers where incorrect.
Mactec54
