585,575 active members*
3,960 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > Stepper or Servo Motor for high Torque
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jul 2021
    44
    This is the old configuration. I made a new housing for the new motor.
  2. #22
    Nov 2013
    4347
    Re: Stepper or Servo Motor for high Torque
    Well, I only need the maximum torque at low speed 0-50rpm because I wind flat wire 5x5mm. My nema 34 12nm is not strong enough
    Now you are talking!! This is much more realistic. With 5x5mm wire I can well imagine you want or need 50Nm to wind but your sure as hell don't need to wind at hundreds of rpm either.
    That suggests a deep reduction gearbox, something like I pictured before with say a 50:1 reduction. Then a 2000rpm motor would give you 40rpm....which is still fast if winding big
    wire.
    You could use a motor direct, but the motor would have to be huge and therefore costly.
    I think you need a motor with a gearbox for high torque/low speed, ie big wire AND another motor perhaps with a modest gearbox that could go much faster with low torque for smaller wire.
    Craig
Page 2 of 2 12
  1. Trying to figure out high RPM servo motor with decent torque?
    By PIVOTALCUSTOMS in forum Servo Motors / Drives
    Last Post: 11-01-2022, 11:55 AM
  2. Need a high torque Stepper motor ?
    By Scott in AZ in forum Community Club House
    Last Post: 06-20-2008, 11:26 PM
  3. High Torque , High Bandwidth Motor or Servo
    By mastabib in forum Benchtop Machines
    Last Post: 09-26-2007, 08:09 AM
  4. Stepper Motor High Torque Low Amp
    By Sanghera in forum Stepper Motors / Drives
    Last Post: 03-22-2005, 01:16 AM
