585,662 active members*
3,012 visitors online*
    Jul 2012
    18
    CNC cycle not running
    Hi All,
    We had a machine breakdown where we found the I/O Link modules were faulty. We replaced this and also found some shorted wires that we repaired. What happens now is that the cyce start will not work. I see when we press the cycle start it gives a signal G7.2 to the CNC but the machine does not do any thing and no errors.
    I also see the output from the CNC F000.5 is not coming on.
    Can anyone advise what other signals I may require for the CNC to run its cycle?
    Jul 2012
    18
    Re: CNC cycle not running
    Hi All further to this. I checked G8.5 for feed hold and this is on.
    Dec 2009
    952
    look in the ladder and check who is making G8.5 on and what is holding the feed
    Jul 2012
    18
    Quote Originally Posted by zavateandu View Post
    G8.5 Is supposed to be on. If it goes off then the CNC Signal resets. I am trying to find out what other signals I need to take a look at.
    Jan 2013
    474
    Quote Originally Posted by BrendanDixon View Post
    Hi All,
    Given your earlier I/O link issues and wiring short, I would go back over everything, checking every current input and output to the wiring diagrams. I would also check the safety relays and functions, door closed and locked signal, tool and work holding etc,
  1. Running a probing cycle after a certain amount of parts
    By ball_fondler in forum Haas Mills
    Last Post: 09-06-2021, 03:37 AM
  2. Mach3 g-code not running when Start Cycle
    By NicR in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-18-2019, 08:36 AM
  3. Short cycle time job, lots of parts - Anyone leave spindle running?
    By 74BurkeMVN in forum Tormach Personal CNC Mill
    Last Post: 09-18-2017, 04:09 PM
  4. Running a G84 cycle on a 325J
    By sortafast in forum Tree
    Last Post: 05-20-2014, 07:37 PM
  5. Displaying Cycle Timers while running?
    By donl517 in forum Fadal
    Last Post: 10-01-2007, 04:12 PM
