Hi all!
I would like to make an AMF/IMAO machinable collet for my workshop.
Does anyone understand how the pulling mechanism inside the case is arranged?
inside the base is a nut, capable of up/down movement
od clamping :
... is used normal screw, maybe with bigger than usual head
... this screw makes contact, with the collet, towards the base (z-), and this creates the effect of rotation at the higher surface of the collet
... because of rotation, there is also an effect of pull-down
id clamping :
... is used a tapered screw
... contact with collet is towards the collet surface (z+), and this creates an effect of contrary rotation, so the coolet expands at top
... 2nd effect is that collet rotates reverse at (z-), or at least has the tencendy to do so, but this is less important
please notice, as explained in the bottom zone, that surface contact is only among a ring, not full face
i did not draw them, but pins are used to prevent collet rotation among z axis
is a simple rota to linear mechanism; it may have a drive pin, a lobe ... it is designed to lock at blocking angle, thus the cutting forces to not be able to rotate it back
a cheaper alternative for a regular shop, is to take a 3 4 6 normal chuck, and use pie jaws
even cheaper, if your parts are simple, is a vice with custom jaws;by cheap i don't reffer only material cost, but also the time needed to craft it / kindly
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
