585,974 active members*
4,406 visitors online*
Results 1 to 8 of 8
    Jun 2017
    119
    Machine does not start.
    Hello.
    I've been running the machine frequently and last time was early last week. I powered up the machine today, no changes made in any place loaded some new gcode files. Press start and the machine does nothing. The software moves to the first line of code and just stays there. I have tried gcode files that I ran last week with no issues but they do not work today either.
    Any updates that have happened over the weekend? I have tried updating software and firmware with no results.
    Jun 2017
    119
    Re: Machine does not start.
    It seems like the software just stops working when it meets the G00 code. If I remove this code the program continues until it reaches a new G00.
    Jun 2017
    119
    Removed all the G00 codes from program and it runs as normal.
    Why did the software suddenly decide not to recognize G00 as a code or refuse to move on it? It has been running with same post processor for over 1 year with 100's of files.
    Aug 2020
    131
    Did you by accident reduced rapid speeds to 0%?
    Happened to me a few times and I was wondering why the heck the machine would not move....
    Jun 2017
    119
    Don't even know how to change those settings.
    But yes apparently after some searching around it seems like the traverse speed had been set to 0%.
    Jan 2013
    474
    Quote Originally Posted by MrEmo View Post
    Being switched off may have caused it to default to 0% or someone changed it.
    Jun 2017
    119
    I've got no idea. I am the only one who uses the machine. But it's fixed again now.
    But I have to say it's not the first time around where the software have changed some random setting making me tear my hair out.
    Mar 2017
    1311
    Advice:
    Whenever override value is set for feed, rapid or spindle, button will be colored orange. Makes it easier to notice.
  1. Machine Start up
    By Hydratight in forum Cincinnati CNC
    Last Post: 11-18-2015, 05:24 PM
  2. machine will not start
    By GAGV in forum Bridgeport / Romi Lathes
    Last Post: 11-19-2010, 03:12 PM
  3. New Machine: Where do I start?
    By 777funk in forum Techno CNC
    Last Post: 10-01-2010, 02:53 PM
  4. Start of the machine
    By Konstrukter1 in forum Fadal
    Last Post: 11-05-2007, 07:25 PM
  5. Start w/ this machine?
    By jime in forum Benchtop Machines
    Last Post: 02-19-2007, 10:50 PM
