584,817 active members*
5,140 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Need Help! Migrating from CNC USB controller Mk1 to Mk3/4
    Jan 2015
    Question Need Help! Migrating from CNC USB controller Mk1 to Mk3/4
    Hi there,
    I've currently buyed a new CNC USB controller Mk3/4 and I want to migrate from an old one Mk1. For the drivers, I'm using Wantai DQ542MA.
    I need your help in order to connect the new controller to the drivers, at least for the signal wiring diagram. I've carefully read the Mk3/4 manual, but I want to be sure if this is the correct wiring. Please see the picture from the attachment.
    Previously, I've used common cathode wiring diagram (for the Mk1). Now, in the previous wiring diagram I've used the common anode. There is any advantage/disadvantage?
    P.S. I don't have expertise/skills in electronics, so this is why I'm asking here.
    Thank you very much
    Andrei
    Mar 2017
    1295
    Re: Need Help! Migrating from CNC USB controller Mk1 to Mk3/4
  1. MK1 DIY CNC USB Controller with LICENSE for SALE
    By adidoro in forum PlanetCNC
    Last Post: 10-13-2021, 07:14 AM
  2. MK1 CNC USB Controller Measure tool Z issue
    By CNCRim in forum PlanetCNC
    Last Post: 07-14-2021, 07:50 PM
  3. How to control Huanyang VFD with USB CNC MK1 Controller card
    By Gautier in forum Maintenance DIY Discussion
    Last Post: 10-13-2018, 01:07 PM
  4. MK3 / CNC USB Controller - Plasma Stuttering
    By curacao in forum PlanetCNC
    Last Post: 08-17-2018, 10:51 AM
