585,759 active members*
3,910 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Fa10 mit. Wire EDM. Alarm S02 INIT PARAMETAR ERROR
    Can anyone give a consult about the alarm the manual say to check parameters from the drives but how do i even check those parameters.
    on the drive there is f1 e7 f2 e7 blinking.
    Also how do i know if the nc card is working like it should.
    pls help
    Fa10 Wire EDM Alarm S02 INIT PARA ERROR
    Can anyone give any suggestion about my problem.
    The monitor shows s02 init para error. does this mean that the nc card is not giving parameters to the drives, or the drives lost initial parameters, and if so how do i give them their parameters back.
    Ty for any help given.
    Apr 2018
    131
    Re: Fa10 Wire EDM Alarm S02 INIT PARA ERROR
    I have merged what are essentially duplicate threads. Please, one thread per issue. Duplicate threads become especially confusing if they both get replies.
    FYI, a better approach than duplicate threads is to make an additional post to the original thread, perhaps with more details. A photograph (or a screenshot) can be very helpful.
    Mar 2011
    461
    Re: Fa10 mit. Wire EDM. Alarm S02 INIT PARAMETAR ERROR
    This appears to be posted in the wrong forum. Cincinnati_CNC is primarily for machining cetners/turning centers from Fives Cincinnati (formerly Cincinnati Milacron) or other machines with one of their CNC controls on it. This does not appear to be related to those so would probably get more helpful responses in the correct place.
    Based on your post I don't know what control or drives you have so this may not be relevant, but E7 is frequently an E-stop indicator and F1/F2 designate axis number on the drive.
  1. Fa10 mit. Wire EDM. Alarm
    By BorisShkartov in forum Cincinnati CNC
    Last Post: 03-16-2022, 07:04 AM
  2. Melda 64 control alarm s02
    By RanaAli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-13-2017, 10:59 AM
  3. NEED POST BOBCAD V28 FOR MITSUBISHI FA10 OR FX10 WIRE
    By diemaker89460 in forum BobCad Post Processors
    Last Post: 06-25-2016, 06:57 PM
  4. Biesse 336 Error S02 and S0157
    By zedexnz in forum CNC Machining Centers
    Last Post: 04-06-2012, 10:05 AM
  5. FA10 WIRE EDM
    By CLATHAM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-29-2011, 07:49 PM
