Originally Posted by
Geof
Part way down is a description of how the phase perfect works. As far as I understand there is not any direct relationship between the incoming single phase voltage and the synthesized three phase output. The incoming voltage is converted to DC in capacitors and the three phase is digitally synthesized from the DC voltage.
Geof, According to the installation diagram schematic http://www.phaseperfect.com/files/al...s%20manual.pdf
The 1 phase is passed through as two phases the way it is done in a RPC.
Only the third phase is synthesized from these two, at least that is the way I interpret their diagram.
Al.
Albert E.
