how does Leadshine compare to other Chinese AC Servo manufacturers like rtelligent/lichuanmotor/dorna?
Also I have trouble finding any direct sellers of Leadshine on Alibaba/AliExpress is that normal?
It also need to think about your gear size ,gear box or motor reducer ,motor nm etc when choose servo motor, hope i can help you +8618560201508
have you looked at Delta, they are a step up from all those you mentioned.
https://www.fasttobuy.com/Supply-asdab2-series_c498
Craig
Step up as in higher quality hardware or just because the software is so much better and makes tuning so much easier?
both probably, but I as I don't have a Leashine servo so it would be unfair to make comment about quality of the hardware, but most certainly the set-up
and tuning software puts Delta head and shoulders above Leashine, especially is this is your first foray into servos.
All servo manufacturers tend to copy each other and despite different terminology if you can setup one servo then there is a high probability that you can set up
another, but having software to aid that process is invaluable, especially at the beginning.
Craig
