What's the difference?
Please refer to the 2 XML files attached, they are for MACH3 using a USS. Both are XML files renamed to TXT so I could upload them.
The one titled "Mikini USS Working 05APR23" is working fine.
The one titled "Mikini SmoothStepper" will switch the VFD for forward and reverse, but won't turn the spindle on.
I have compared the files, and don't see what value(s) are different that would make the spindle not work. Can anyone provide a reason it might not be working? I need to understand so I can make sure I make the right choices when setting up MACH4.
CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
