586,000 active members*
4,992 visitors online*
    Apr 2014
    185
    Spindle Speed
    G'day guys,
    I've got a 1100 - Series 3.
    Every time I have to set a tool height, it drives me crazy that the spindle "homes'' first and then
    travels at 110 mm per minute, down to the tool setter. It takes forever!
    Is there an easy way to change the rapid speed of the Z axis for this procedure?
    Michael
    Nov 2022
    12
    Quote Originally Posted by RA-Bowtie View Post
    G'day guys,
    Michael
    Ra-bowtie,
    The probing rough and fine speed can be controlled on the Probe Setup tab within the Probe/ETS tab. In G21 the machine will move to the g37 position then use the Rough Probe Feed f
    rate to drop the tool down to the ets then come up a bit and use the Fine Probe Feed rate to confirm the tool length.
    Apr 2014
    185
    Re: Spindle Speed
    Thanks for the reply... at least I know where to look.
    Michael
  1. Replies: 13
    Last Post: 11-07-2022, 05:16 PM
  2. Replies: 7
    Last Post: 07-15-2021, 05:24 AM
  3. high speed and low speed dual spindle CNC mill
    By GusBiz in forum Mechanical Calculations/Engineering Design
    Last Post: 02-13-2021, 08:54 AM
  4. Replies: 3
    Last Post: 04-20-2019, 11:24 PM
  5. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
