0 active members*
4,653 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Current Commands Bar Feeder Variables not working
    Our ST20 lathe recently had a board go out. It has been replaced, but unfortunately we didnt have a back up of the settings and im struggling to get the Bar feeder working again. It is a Servo Bar 300. When i go to the current commands page where the system variables are to be set for the bar feeder, i am not able to edit any of the values. i type in the numbers i want and hit write, and nothing happens. Ive searched thru the settings to see if something needs to be turned on but i have been unable to find anything. The lathe has the classic control. Has anyone experienced this that could help me figure out what is causing this?
    I'm running into similar issues on Haas ST20 with the 300 bar feeder. Recently was purchased. Resolved the first problem with Param 321: pusher not returning to home for push rod.
    Now I can't get command page to alter any variables. I thought I've tried loading a bar register, but nothing.
    Hopefully your problem was resolved.
  1. Replies: 1
    Last Post: 07-06-2020, 05:17 PM
  2. Bar feeder oil choices to help with vibration inside the feeder channels
    By lasernerd in forum CNC Swiss Screw Machines
    Last Post: 05-19-2017, 10:59 PM
  3. CAV bar feeder/bar loader--part numbers?
    By calscrew_purch in forum CNC Swiss Screw Machines
    Last Post: 08-17-2016, 07:04 PM
  4. Mori S-15 Bar-Puller/Bar Feeder Parameters
    By MPMInc in forum Hardinge Lathes
    Last Post: 12-05-2015, 05:15 PM
  5. LNS bar feeder not working in mazatrol program, W-axis pos. malf using p/c
    By TJM200MSY in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-16-2014, 12:46 PM
