585,877 active members*
3,156 visitors online*
    Dec 2022
    5
    DTHC IV control issue
    I am running Mach3 and CandCNC Ehtercut with DTHC IV. There is an issue when ever THC is activated, eg. after a corner, and actual voltage is higher than the set point, it does not give any command to lower the Zaxis. How ever if i increase the set point over or equal to the actual voltage the control comes alive and i can lower the set point. I have tried playing around with the dynamics parameters for DTHC with no success.
    Dec 2022
    5
    Re: DTHC IV control issue
    Turned out that it was the "tip saver" that blocked the movement. Increasing the tip saver % allowed the THC to control z-axis after activation of THC, since voltage usually was above the deviation limit.
  1. DTHC , need help
    By LDRTABLE in forum Want To Buy...Need help!
    Last Post: 02-13-2017, 04:37 AM
  2. Replies: 0
    Last Post: 10-08-2016, 05:36 PM
  3. $10 DIY DTHC
    By Enrique Riojas in forum Waterjet General Topics
    Last Post: 02-02-2014, 05:44 PM
  4. DTHC
    By fabguy in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-04-2012, 02:25 PM
  5. DTHC
    By MAS in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-19-2011, 11:40 PM
