585,573 active members*
3,673 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Anybody use nitriding to harden molds?
    Jun 2008
    262
    Hello. I have 4140 half hard molds. They exhibit too much wear, likely from inexperienced operators.
    Has anyone ever used plasma nitriding to give a good hard skin to this, or any steel?
    Warping of course is my big concern.
    Jun 2015
    4154
    Re: Anybody use nitriding to harden molds?
    hy i did not used nitring, but chroming
    also, wear on some big hard parts, was fixed with additive metalization, then refreshing the surface / kindly
    Jun 2008
    262
    Thanks a lot Deadly, I make molds but only with rotary tooling, not much EDM.
    Therefore, I can't work with totally hard metal, like Rockwell 55 C.
    I would like to use 4140 hardened to 32 HRC and treat the surface.
    Has anyone needed this? Obviously the surface treatment would be done after almost all the machining is done, except for polishing.
    Also obviously, warpage is really a dealbreaker.
    Any mold makers out there??
    Nelson
    i build the braces that keep american teeth straight......tick tick tick
  1. inserts to machine harden material
    By cob in forum Diemaking / Diecutting
    Last Post: 03-25-2020, 07:32 PM
  2. Plasma cutting harden steel?
    By DavidhCNC in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-29-2015, 06:37 PM
  3. Nitriding general information/discution
    By ckielcave in forum Material Machining Solutions
    Last Post: 09-20-2014, 11:30 PM
  4. two aluminum molds ( for composite parts , simple molds )
    By yoi in forum North America RFQ's
    Last Post: 01-17-2014, 04:35 PM
  5. equipment for surface coating metals, e.g. nitriding
    By autobot in forum MetalWork Discussion
    Last Post: 08-14-2012, 08:41 AM
