Greetings,
I'm working on a partial linear rail conversion for the Z axis of my benchtop CNC mill. I'm using four supposedly genuine Hiwin HG25 blocks and matching rail, purchased new. Given the relatively modest non-production use for my machine, I decided manual greasing via zerks is perfectly fine. I settled on using Mobil Mobilux EP 1 grease as it's a readily available general purpose lubricant recommended in the Hiwin documentation.
I was attempting to do the initial grease procedure for my blocks last night, and I'm not confident in my success. Following the procedure in the Hiwin documentation for pumping 0.8cm^3 of grease (determined to be 2/3 of a lever pump of my particular grease gun), moving the block 3x, and repeating this process 3x, only one of my 4 blocks seems to have grease reaching the bearings. I can tell there is a difference in feel on one block, as its movement became more "viscous" and quieter as the grease worked its way into the ball bearings. The other three blocks still feel and sound like they are running on the lightweight protective oil that the blocks had in them from shipping.
I tried to pump some additional grease into the other 3, which is also recommended in the documentation for cases when you don't see a film of lubricant on the rails after the standard procedure. The grease is definitely making it through the zerks, as it eventually squeezes out between the green plastic and metal body of the block on the side where the zerk is installed. But, still not much of any change in the feel or sound of the blocks running on the rail.
One thing of note, the one block that did seem to work, is of slightly different appearance from my other 3. I was told by the vendor that this is merely an earlier production run from Hiwin, but they should all be the identical specs.
Here's how I have the zerks set up. Assuming I'm reading the documentation right, nothing special needs to be done to use these end ports, other than capping off the end you aren't using, which I've done with the included screw. It's only when you use the top or side lubrication points that you need to poke holes in plastic to open up orifices for the grease.
Here's the one block of the four that seemed to take lubrication as expected. Note the slightly more "rough" appearance of the non-ground surface on top where the laser etching is.
Any suggestions?
thanks,
Steve
