584,874 active members*
4,954 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM-B 6000 Parameters not visible / Spindle orientation
    Jul 2021
    Hi all,
    I have a VMC with a Fanuc OM-B controll. I need to adjust the spindle orientation because it is slightly off.
    As far as I know the spindle orienattion Parameter is #6577.
    However my control jumps from Parameter #3199 straight to #8100.
    Does anybody know how to enable the #6000 parameters or another way of setting the spindle orientation?
    Jul 2021
    Re: Fanuc OM-B 6000 Parameters not visible / Spindle orientation
    Seems like I can adjust the spindle orientation with a pot on the ac servo amplifier.
    I guess I have to adjust the "Position Shift".
    As an alternative, you can adjust "In-Position" for the high and the low gear. Has anybody a clue what the in-position is?
    Is Position Shift the right Pot to tweak the spindle orientation?
    Page 56 - 62
    https://s3.amazonaws.com/Icarus/DOCU...nuals_1787.pdf
    May 2023
    6
    Hi, I need the manual of this Fanuc OM-B! Do you have it?
    I'm looking for a cheap solution for monitoring this Sigma VC1000 milling and this machine has a Fanuc OM-B.
    Thank you!
    Aug 2018
    44
    [6000 séries parameters are only for serial spindle... Not supported by fanuc 0B ...
    The variable resistor called position shift on your orientation pcb ( probably a20b-0008-0030 ) IS only to shift the position about less than +- 2°...
    QUOTE=kalibur;2550824]Seems like I can adjust the spindle orientation with a pot on the ac servo amplifier.
    Page 56 - 62
    https://s3.amazonaws.com/Icarus/DOCU...nuals_1787.pdf[/QUOTE]
  1. Fanuc 0M Spindle Orientation Error
    By SceptreCNC in forum Fanuc
    Last Post: 11-13-2016, 07:50 AM
  2. Spindle orientation Fanuc OM
    By kirby in forum Fanuc
    Last Post: 03-28-2015, 12:55 PM
  3. Fanuc OM-C spindle orientation parameter
    By hotiron in forum Fanuc
    Last Post: 07-16-2014, 04:48 AM
  4. FANUC-6M SPINDLE ORIENTATION
    By CHANDRU in forum Fanuc
    Last Post: 04-18-2009, 07:05 PM
  5. fanuc OM-D spindle orientation parameter?
    By meadowtech in forum Fanuc
    Last Post: 02-09-2009, 06:15 PM
