585,978 active members*
4,130 visitors online*
    Aug 2006
    TNC 410 controller cable
    I've offered to help a local workshop get their Bridgeport VMC800 LR'30 Digital up and running. I've always wanted to get my head around CNC. It has a Heidenhain TNC 410 controller. C. 2005, the controller has an RS232 DB-25 port so I need the correct USB adapter and cable. I believe a suitable USB-to-RS232 (DB-9) is the DIGITUS USB to serial adapter (DA-70155-1). This one has the Prolific chipset (PL2303RA), mentioned in Heidenhain documentation for their USB driver.
    As this Digitius adapter is DB-9, I am looking for a DB-9 to DB-25 cable. Although I have a pinout diagram for the controller, it appears manufacturers do not publish a pinout diagram, so if anyone can recommend a cable known to work, I'd be very grateful.
    From the diagram, it looks like the TXD & RXD cross, which I believe is known as a null-modem cable?
    Attachment 492464
    Thank you in advance.
    W.
    Aug 2018
    Re: TNC 410 controller cable
    I used this cable https://www.scorptec.com.au/product/...5-icusb232db25
    StarTech USB to RS232 DB9/DB25 Serial Adapter Cable, Male to Male
    I also have a TNC410 and it does work. Just make sure the serial port in device manager for the usb adapter is the same in tnc remo.
  1. heidenhain tnc 410 parametri macchina
    By luigiivano in forum HEIDENHAIN -> TNC
    Last Post: 06-04-2021, 08:54 PM
  2. solidcam - HH TNC 410 M post
    By MattTaylor24 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-22-2019, 03:43 PM
  3. Heidenhain TNC 410 problem
    By Dean-R in forum Bridgeport / Hardinge Mills
    Last Post: 10-28-2014, 07:23 PM
  4. Heidanhain TNC 410
    By deep44 in forum Community Club House
    Last Post: 05-09-2013, 01:52 PM
