585,605 active members*
3,263 visitors online*
    May 2005
    64
    spindle work stop
    My lathe is a Haas HL-1, but this question would apply to anyone using a kitagawa 8" power chuck on a haas lathe.
    I was trying to comeup with a solution for a spindle work stop, but on this machine, the draw tube moves to actuate the power chuck. This is pretty much the standard for all cnc machines with power chucks, I would imagine.
    A commercially available stop like the one Yuasa offers grips the spindle bore, so this won't work. The ID of the chuck in the front is called the Front Cover in the Kitagawa manual. I could grip the ID of this part, as I do on my Daewoo. I made a close-fitting slug that has a screw in the face that jacks a ball bearing axially against the chuck's ID.
    An expanding mandel comes to mind, as well.
    I also considered that I could make a new "front cover" that included a flat back, that I could drill and tap for this kind of work.
    I'm curious what others are doing to locate work in hard jaws or thru-bored soft jaws.
    Jul 2005
    12177
    Quote Originally Posted by gromit68 View Post
    .....I also considered that I could make a new "front cover" that included a flat back, that I could drill and tap for this kind of work.
    This what we have done on several lathes. For work that is longer than the depth of the chuck jaws but small in diameter we weld a blanked off tube onto the new cover plate and fasten stops into the bottom of the tube.
  1. spindle will not stop fadal 4020
    By choppermex in forum Fadal
    Last Post: 06-17-2016, 09:59 AM
  2. Spindle/e-stop/grn Light/brake Wiring
    By TPMX in forum Bridgeport / Hardinge Mills
    Last Post: 05-06-2007, 02:46 AM
  3. VMC-15: Spindle Would Not Stop !
    By StormWerkz in forum Fadal
    Last Post: 04-25-2007, 05:30 PM
  4. Spindle Motor Stop
    By rweatherly in forum Mach Software (ArtSoft software)
    Last Post: 11-25-2006, 05:28 PM
  5. Fanuc 0 M - Spindle Stop
    By Uncle Buck in forum Fanuc
    Last Post: 07-01-2006, 12:18 AM
