some time ago when I was building my machine, and had pretty much run out of money, I made this headstock. Its made out of 100mm x 100mm x 9mm RHS,
and is OK for the little 800W spindle pictured but is too 'wobbly' for a bigger more powerful spindle. I'm now in a position to make a new one.
I am a traditionalist in the sense I favor steel and/or iron for machine parts, but many hobbyists favor aluminum, epoxy granite, high performance concrete among others.
I have traded 'blows', figuratively speaking, with other hobbyists about different materials and techniques. My thought was to throw the design open so that anyone who has a
favored material or technique can contribute.
The part itself is about 275mm x 275mm x 300mm, and so within reason, any decent technique should be affordable for me to actually make. I have drawn a rough sketch.While the major
external dimensions are fixed, many of the small details are not. For instance I've shown it as a 25mm thick shell, thinking that I might cast it in iron, but the drawing would be needs
be modified to include draft for casting. Feel free to modify the drawing should you need to do so for your favored construction.
I will use Fusions FEA tool to determine the rigidity of various designs. My machine is about 25N/um at the moment, and I'd hoped for better when I built it, about 50N/um. There are
things that I have yet to do on the frame that will make 50N/um achievable so this part (headstock) will need to be at least 200N/um, and preferably 300N/um so that it does not
compromise the overall stiffness of the machine.
I have a 750W servo direct coupled to a 32mm diameter 5mm pitch ballscrew so weight is not critical. I could tolerate this part being 100kg, but would prefer to keep it to 50kg
or under.
I'm guessing that if I cast this part it will cost around $1000NZD ($650USD). So I have some budget, but its not unlimited either. If someone wants to use boron fibre like was used
in the F15 Eagle.....its not going to happen. I can't afford 'pie in the sky' solutions.
Craig
