585,902 active members*
4,644 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Wont recommend folks build machines from polyester counter top remnants anymore.
Results 1 to 1 of 1
    May 2013
    480
    I have about 1 inch of creep across 5 feet on a 3/4" thick bar, under its own weight, most of that creep is in the last couple months when it would have been over 100F for 8 hours a day.
    Also have about 1/8th inch of creep across a 5 foot long 1.125" thick bar, under its own weight. Thr larger bar is white, and would not have warmed up as much.
    It takes about 50 to 60 pounds to straighten the 3/4” 2.5" wide bar across its weak axis.(im supprised it didnt break)
    These are actually backsplash remnants and appear to be factory cast in forms and they can be found in scrap piles as straight as .001" per foot across the width. (Thickness is not as well controlled)
  1. Milltronics VM 16 wont rigid tap anymore?
    By bobbas41 in forum Milltronics
    Last Post: 05-17-2022, 04:10 AM
  2. Milltronics VM 16 wont rigid tap anymore?
    By bobbas41 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-11-2022, 01:08 AM
  3. V25 Wont read solidworks files anymore ?
    By Shottie_gp in forum BobCad-Cam
    Last Post: 09-18-2014, 07:01 PM
  4. For those folks looking to build their own....
    By DDaland in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2008, 04:07 AM
