584,808 active members*
5,158 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Help needed to transfer gcode files from Pc to 8055tc
    Mar 2004
    136
    Hi All,
    After some advise on how to send files from pc to Fagor 8055 tc Lathe controller.(older version earlier 2000 model)
    Cant see anything in the manuals , but i see a serial port on the side so I'm assuming i can.
    here is a screen shot of the front panel Click image for larger version.
    Any ideas ???
    Aug 2009
    1566
    Re: Help needed to transfer gcode files from Pc to 8055tc
    ...this may help you. I see a link for the cable wiring and some free software here>https://atrump.com/images/tech_suppo...munication.pdf
    There is also Putty you can use to download. > https://www.putty.org/
    Good luck hunting,
    DJ
    Mar 2004
    136
    Smile Re: Help needed to transfer gcode files from Pc to 8055tc
    Thanks for that will check it out
    Mar 2004
    136
    Had a look , i cant get to the screen that says load. Not working for me.
    Ive checked manuals and cant see anything
    Surely there's a way to send a gcode file to the machine.
    Mar 2004
    136
    further to my last .........................Shift key then ESC works , happy days
    i was holding both keys down together
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. Transfer Files from/to pc machine
    By nodochau in forum Okuma
    Last Post: 03-21-2020, 04:01 PM
  3. Trumpf gcode transfer
    By Pobes in forum Laser Control Software
    Last Post: 12-27-2016, 10:07 PM
  4. TRANSFER FEATURES BETWEEN DIFFERENT FILES?
    By Tolyatti in forum FeatureCAM CAD/CAM
    Last Post: 10-20-2016, 01:20 PM
  5. How to transfer files to 840D?
    By abdous in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 08-14-2010, 07:22 AM
