hello friends .
I'm electronics technical. maintenance electronics board and make modification and solution for old system. hardware and software. I have fanuc o-tc series control.i found some problems in hardware. 1st problem makes cut off for battery line. so it's lost parameters. My customer don't have back up to parameters just have the parameters manuals .
trying input all parameters manuals but didn't work also The operator's panel didn't work and unable chiose edit or automatic mode because this mode touch key's in The operator's panel not select switch. so I'm need back up file to sending it with laader or dnc to control. after it's working we can edit different parameters.
Fanuc series o-tc type -A02B-0098-B501
My [email protected]
