Hi fellas.
Anyone have an example of a program that uses multiple fixtures and multiple coord rotations?
Just got a job in with some tight tolerances, and their fixture was apparently built by someone very drunk ! Locations and rotations are all out of whack.
Should I map all of the rotations, store them as variables, then load the vars & call a G68 before each E instance ?
Is there a way that I can dial in the fixture's subplate ? So it will rotate the fixture nests based on the readings of the subplate only?
It would be a major PITA to have to dial in every nest when we load the subplate.
