585,727 active members*
4,148 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Milling parts to stock and thickness ?s.
    Jul 2007
    129
    Most of our parts that get machined get milled to rough length, maybe skim the top of the stock, then flip, machined to finished length and thickness.
    Then what ever needs to be done.
    I don't see an option for leaving stock.
    What would be the best way or ways to perform these task in Bobcad?
    Thanks.
    Jul 2007
    129
    Anyone have an ideals, or maybe how to offset the profile?
    Thanks.
    Jan 2006
    4396
    Offset your part profile so it cuts larger than you need.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    107
    Another way!!!!
    If you use cutter comp to machine the lenght of the part, then simply lie to the machine that the tool it is larger than the actual size of it and the machine will then stay away from the programed path by that amount (ie: if you want to leave .02 for finish, tell the machine in the tool diameter register for that tool that the tool is .04 bigger that the actual size). Cutter comp. is a wonderful function and it eliminates the old fashion offsets. It allows you full control of your part size without changing the G code.
    Hope this helps.
    Best regards,
    Sorin
    www.cadcamtrainer.com
    Any society that would give up a little liberty to gain a little security will deserve neither and lose both.
    Benjamin Franklin
  1. Milling flats on the side of round stock
    By MichaelHenry in forum SprutCAM
    Last Post: 10-22-2007, 12:36 AM
  2. What spare parts would you stock?
    By keen in forum Tormach Personal CNC Mill
    Last Post: 09-07-2007, 10:44 AM
  3. DIY CNC Router/Milling Parts
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 08-17-2006, 08:15 PM
  4. Cnc Milling Micarta Parts
    By Cold Fusion in forum Employment Opportunity
    Last Post: 01-20-2006, 06:08 PM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
