585,954 active members*
4,414 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Meshcam - stand alone vs CAD integrated
    Apr 2007
    1955
    Hi
    I am hoping to clarify an important point for me.
    A friend of mine wants to draw up a 3D part in Rhino, and have me cut it on my (under contstruction) DIY 3 axis router.
    The router will be running Mach III (at least, that is the plan)
    I don't own a copy of Rhino, and have no plans to buy it, at least near term.
    Questions
    1) Can I use a 3D CAD file from Rhino (emailed to me), load it into a stand- alone copy of Mesh CAM, and make tool paths / G code from it ?
    2) Can the cut viewer software see the entire image of what is going on with the part and tool paths run in this mode (no Rhino s/w)
    Jul 2004
    127
    Although I've never used Meshcam, they appears to offer a 60 day demo. This should give you answers to any questions you may have.
    http://www.grzsoftware.com/download.php
    -Matt
    Apr 2003
    470
    He can export it as an .stl file and Meshcam use it.
    Nathan
    Have the friend export an .stl file from Rhino. You then load the .stl file in to MeshCAM, create your toolpaths, and save the g-code. Cut Viewer is a separate program from MeshCAM, so you then load the g-code into Cut Planner and have it display the simulation. (Provided you purchase Cut Viewer along with MeshCAM.) Cut Planner gets the stock and tool info from comments that MeshCAM adds to the g-code file.
  1. New 4 Axis Integrated Controller Product announced
    By Torchhead in forum News Announcements
    Last Post: 11-27-2006, 09:06 PM
  2. integrated stepper/driver
    By J Solinger in forum Stepper Motors / Drives
    Last Post: 10-09-2006, 03:08 PM
  3. USB Controllers & Integrated Stepper Motors
    By tt_raptor_90 in forum Stepper Motors / Drives
    Last Post: 01-29-2006, 11:59 PM
  4. Integrated motor/drive/controller
    By NEATman in forum Community Club House
    Last Post: 03-16-2004, 08:35 PM
