585,729 active members*
4,633 visitors online*
    Oct 2005
    29
    CNC4PC Boards
    What's the difference between their breakout board and the parallel interface card. For safety sake would it be better to go with the interface card or save the money and run the breakout board? Money isn't the issue since it's only about 25 dollars. I just don't want to put something in that's not really needed. I'm making a 3 axis CNC Router.
    Mar 2007
    23
    Well I used their C-10 bidirectional breakout board in my conversion of a old techno isel router. Just a couple of things I liked is the fact that the board can take voltage from like 3.3 v to 5 v, the pull down resistors on the input circuits leave no open air connections, and jumper options add versatility for expansion. And like you said it's only 25.49 for me it was a no brainer.
    Jack&Master
    Sep 2003
    1113
    Suppose it also depends on which axis cards you'll use. For example, the xylotex board doesn't require/need a BOB -- unless you're gonna put a couple together and need a way to get all the LPT headers sorted out.
    I went with the less expensive and am putting 2x 3 axis Xylotex together to get to 6.
    :cheers: Jim
    BTW the cnc4pc guys were real quick with questions and support
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  1. Open Source Boards Available, Stepper Drivers and Break Out Boards
    By pminmo in forum Open Source Controller Boards
    Last Post: 06-23-2018, 01:46 AM
  2. CNC4PC multi board
    By krymis in forum CNC Machine Related Electronics
    Last Post: 07-29-2008, 01:49 AM
  3. cnc4pc multifunction board Rev 2
    By jguillen08 in forum CNC Machine Related Electronics
    Last Post: 01-14-2007, 04:27 AM
  4. Xylotex and cnc4pc
    By Eclipse in forum Xylotex
    Last Post: 12-22-2005, 05:14 AM
