Hi all
just had a Mori machining centre arrive in all seems to be working nicely but have a problem with Absolute position readout.
Have set manual Absolute to on in settings which has sorted my X and Y both now reading 0.0. at workpiece zeros. However the Z at programmed zero position is giving me the tool length ie whatever tool i bring in to zero the figure in Z matches tool length setting in tool file.
On other machines (including 11Ms) i have used, It always took the tool length from the absolute when u called G43 H1 Z0. so you new where the tool was in programme check. G43 is obviously working as it goes nicely to position every time it would just be nice to see it on the prog check page ??
Is it a parrameter change ?
Appreciate any help as im sure im going to bang this m/c sooner or later in this state.
Mike
