There is a parameter setting that can be used to adjust the orientation senitivity. SETP command gets you to the the paramenter setting pages where that setting can be found. The factory setting for the machine is written in the inside back of control panel door. The paramener is called ORIENTATION FACTR: and it will have a setting number range. The user manual recommends this should be only be adjusted by a factory service tech. But should you try to make this adjustment only change it by 1 up or down and test to see how it affects the orientation. Then adjust by 1 increment at a time and test again until it works best. Should you find the adjustment is different than the factory setting recorded in the back before you made any adjustments you might try the original setting first. (Keeping note as to what it was.)
Safety - Quality - Production.
