585,992 active members*
5,978 visitors online*
    Feb 2007
    48
    Gecko motherboard
    Does anyone know if there is a product out that will integrate up to four Gecko 203V's on a single board so you don't have to manually wire the terminals? It seems like a breakout board could be integrated into this as well as a power supply. I thought I saw a picture like this on the ZONE, but I might be dreaming. ...i'm not being lazy, just trying to eliminate wiring errors.
    drafterman
    Mar 2004
    222
    maybe you lookin' for thishttp://www.pmdx.com/PMDX-131/
    mhel
    "This is intentionally left blank."
    Feb 2007
    48
    I think that must be where I saw it...but it doesn't look like it works with the 203V's (yet). Do you know any pros/cons to this? I don't seem many folks using this combo.
    I appreciate this. Thanks.
    May 2007
    111
    CandCnc has them. www.CandCnc.com He has models for the servo and stepper geckos. I have bought the stepper module. Works for 201 or the 203v geckos. Here is a picture of my setup using them. One board handles 2 geckos.
    So you buy 2 boards and the mounting plate and one board goes on top and one on bottom. Mounting plate is also the heatsink.
    You would need the MTA100 card and mini-io card to go with them at the least.
    He has a combo here and all of his manuals are downloadable. http://www.candcnc.com/PopularCombos.htm check out the modular quickstepper build. He also gives out the dxf of the mounting plates if you had rather build your own instead of buying.
    Just a satisfied customer.
    Jun 2005
    180
    I use a campbell breakout board, though this board is referenced +5V there is a test terminal pc ground which is what I wired my 203V to. It works fine, maybe bob has updated the board now.
    http://www.campbelldesigns.com/
    Haydn
  1. EZTrack DX Series 2 Motherboard upgrade.
    By Knausscpa in forum Bridgeport / Hardinge Mills
    Last Post: 10-03-2007, 03:01 AM
  2. New motherboard/processor
    By spoiledbrat in forum Computers / Desktops / Networking
    Last Post: 05-29-2007, 02:52 PM
  3. Newb with Bridgeport BMDC/motherboard issues
    By ralph@nes in forum Computers / Desktops / Networking
    Last Post: 02-27-2007, 12:57 AM
  4. Haas controlers, the PC104 motherboard and DOS...
    By crayner in forum Haas Mills
    Last Post: 12-22-2006, 12:10 AM
  5. Mach 3 and ITX Motherboard?
    By DennisCNC in forum Mach Software (ArtSoft software)
    Last Post: 11-22-2005, 04:04 AM
