585,764 active members*
4,341 visitors online*
Page 131 of 131 3181121129130131
Results 2,601 to 2,602 of 2602
  1. #2601
    Feb 2009
    52
    Re: Excitech Cnc Router Purchase
  2. #2602
    Mar 2018
    Re: I found this but......
    Quote Originally Posted by bananafish View Post
    I found an English DSP manual which I have downloaded from this forum.
    Here is the copy.
    Home Setup
    Home Function
    “Home” is the machine origin. “Go to home” refers to moving all axes back to the machine
    origin. Home position depends on home sensor. Normally there are 3 sensors on a 3-axis
    machine. “Go to home” operation sets up the relationship between the machine and the
    working co-ordinates. Many system function applications rely on this operation, such as stop
    point save, power off reboot and so on.
    It is good practice to home a machine after switching the power on.
    If you enter the menu by pressing ,"MENU" please press "STOP/CANCEL"to exit and return to MANL
    as no changes are required here under normal use.
    Home Operating
    When the power is turned on, “Go to Home?” appears on the screen: this is a question
    which will need to be answered by the operator:
    Pressing "ORIGIN/OK"means “Yes”- the Z axis moves first; when the Z axis arrives at its home
    position, the X and Y will also move to the home position.
    Pressing "RUN/PAUSE/DELETE" means “No”- the 3 axes do NOT move to their home positions.
    Pressing any other KEY- Only the Z axis moves to home position; X and Y do NOT go home.
    When the machine is moving to the home position, you can press the KEY to stop
    “Homing”. The controller is now in Manual Mode. Pressing "HOME/9" will move the machine to
    home when in manual mode.
    Pressing "XY-0/4" will zero X & Y. Pressing "Z-0/8" will zero Z creates an origin point which
    the pendant controller uses when running a CNC program.
    Pressing will move the machine to the origin point for the current working
    coordinate when in manual mode.
    1X 0.000, 1Y 0.000, 1Z 0.000
    According to this manual. Origin and Home should be the same which is XYZ0.
    I have set the new XY zero point by pressing "XY-0/4".
    After reset new XY zero point when I press "ORIGIN/OK" the spindle goes to new XYzero point. But when I press "HOME" key spindle goes past the point till hit the limit sensor.
    Is this normal ?
    I need a copy of this manual. Could you please share it to me.
  1. RemainCNC NZ Excitech 1530 router.
    By Big S in forum Excitech routers
    Last Post: 03-15-2018, 06:25 PM
  2. post processor for Excitech router
    By blade625 in forum BobCad-Cam
    Last Post: 09-12-2013, 06:19 PM
  3. Excitech 1212 router down, need help.
    By JacquesLeDick in forum Excitech routers
    Last Post: 08-25-2012, 07:23 AM
  4. Excitech router with NC Studio and Visualmill
    By DaRipper in forum Excitech routers
    Last Post: 04-30-2012, 12:53 AM
  5. Excitech new changes for CNC router
    By dianafeng in forum Excitech routers
    Last Post: 12-02-2008, 02:14 AM
