585,894 active members*
5,184 visitors online*
    Oct 2007
    LazyCAM - Mach3 Scale
    We have been cutting using Mach3 and using LazyCAM to convert from DXF to G-Code. We recently updated to LazyCam Pro and now we are having problems cutting to the correct size. It is supposed to cut 18 inches tall and only cuts 4 inches. I have looked through the settings but havent had any luck solving the problem. Any suggestions?
    Is the .dxf the correct size? Is the g-code incorrect, or are your steps/unit set wrong?
    Sep 2004
    149
    Sorry if this seems like a smartass question, but I don't know anything about Lazycam- is Lazycam open source software? Where would I find the source code?
    Dan
    No, it's not. A demo is included with Mach3.
  1. Need to make scale tire mold for 1/6 scale car
    By thuffner3 in forum Moldmaking
    Last Post: 04-29-2008, 06:57 AM
  2. LazyCam
    By wjfiles in forum Machines running Mach Software
    Last Post: 09-12-2007, 02:33 PM
  3. Need help with lazycam
    By jeffg in forum Mach Mill
    Last Post: 05-31-2007, 05:43 PM
  4. Lazycam
    By dan dimock in forum Mach Software (ArtSoft software)
    Last Post: 04-15-2007, 01:44 PM
  5. Help with LazyCam
    By randyf1965 in forum Mach Software (ArtSoft software)
    Last Post: 04-26-2006, 11:20 PM
