I'm not personally familiar with the unit, but my guess is it would be a high frequency start type cutter? Pretty much any plasma cutter can hook up to our system if you can get a trigger loop from it, however interfacing it and making it work is another story. If it was high frequency we would recommend shielding and grounding for just about everything in the system, just to keep it from interfering with the components. Also the Height Control would be another aspect, can we receive the raw arc voltage from the unit, as well as will the torch fit in our height controller mount?
In the end it may be easier to get a Cutmaster 81 and then use the 80xl as a hand unit.
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
