534,885 active members*
3,452 visitors online*
Page 41 of 41 31394041
Results 801 to 802 of 802
  1. #801
    Registered
    May 2006
    179
    Re: Rotary table indexer
    Quote Originally Posted by wiseman9986 View Post
    I know this has been asked before but I couldn't find a good answer what would be a good stepper motor and driver for a 10" rotary table
    For 'normal' use a typical Nema 23 motor of around 2-4A will easily spin a 10" table.
    I use a similar motor but set the current low to just over 1A and via a 90:1 worm that turns a 10 inch swing lathe head (with drive motor still engaged) along with any work in an 8 inch chuck without any problems.
    As the load on the stepper gets higher the torque available falls, so worse case you may need to run it slower but for division speed isn't that much of an issue.
    You can get around this by increasing the supply voltage to the driver (if it's higher than the safe supply voltage for the controller then you would need a separate power supply for the controller - a small 12v wall wart type would be fine).
    So in short, find a Nema 23 motor of around 2-4A and a suitable driver with similar capabilities. (Preferable a driver with half step capability - which should be most).
    The driver doesn't need to be anything clever, just a cheap driver off eBay. They're cheap enough so you can buy a spare or two, although avoid anything that uses the L298 chip and keep the voltage a little lower than the max rated voltage.
  2. #802
    Aug 2020
    3
    Can anyone recommend a stepper driver, I had a ?Stepper™ : CNC Stepper Motor Driver Board which worked perfectly for 10 years. It has now failed and I can’t find the same one. I have tried a TB6600 stepper driver and a Stepperonline DM420Y bothe of which I cant seem to get the steps correct with. There is some microstepping issue that I can’t figure out. The old ?Stepper™ had just full, half, quarter, and eighth of which I used Half Step mode.
  3. #803
    Registered
    May 2006
    179
    Quote Originally Posted by Redbrown View Post
    Hi, the cheap and cheerful TB6600 should work fine. I use them all the time with no problems.
    Set them to half step (400 steps) and in setup on the controller find "Swap Clock Pulse" and make sure it's set to "High" (the default is "Low" for some obscure historical reason that escapes me now - when I update the firmware next I'll flip it, most drivers require it high).
    The only other possible issues are "steps per 360" is incorrectly set or there's some slippage in your hardware.
    Hope that helps.
    Steve.
  4. #804
    Aug 2020
    3
    Cheers Steve I will have a look tomorrow thanks for the advice.
  5. #805
    Aug 2020
    3
    Reinstalled the TB6600 4.5A CNC Single-axis Stepper Motor Driver Board (ebay) with no problems. Thanks again.
  6. #806
    Registered
    Jun 2005
    6
    Hi, All
    Just ordered two of the Built and Tested Modules, Keypads and Overlays from Steve Ward, a great looking product.
    I'm currently working in Germany, glad to have found this group
    Heres my youtube channel for the curious.
    https://www.youtube.com/user/CeeltdNew
    Carl
  1. Stand alone rotary table indexer.
    By kwackers in forum PIC Programing / Design
    Last Post: 09-10-2019, 04:15 PM
  2. CNC Rotary Indexer/Table
    By desman in forum Commercial CNC Wood Routers
    Last Post: 08-11-2015, 03:32 PM
  3. 4th Axis CNC Rotary Indexer Table Plans
    By Modular CNC in forum News Announcements
    Last Post: 05-11-2011, 07:55 PM
  4. Manual indexer-rotary table vertical
    By silverfoxx03 in forum Want To Buy...Need help!
    Last Post: 02-18-2011, 09:04 PM
