586,024 active members*
4,176 visitors online*
    Aug 2004
    309
    breakout board suggestions for mach and lathe
    I have been happily using deskcnc for about 4 years now but would like to play with Mach3 a little. I am converting a 14x40 lathe with ball screws , geckos and DC servo motors and would like a little input on which breakout board would be best suited for my build. PWM output for vfd and spindle encodrer input are important , would also like to be able to interface , tool changer/turret , mist and flood selonoids as well as possibly a couple of aux outputs .New to mach, any advice welcome.
    Aug 2004
    309
    I thonk this is the board I am going with http://www.cnc4pc.com/Store/osc/prod...products_id=48
    May 2005
    1810
    I recommend the above board also. My entire set-up is about 2 years old and was constructed completely from boards from www.cnc4pc.com. Good stuff.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Sep 2005
    127
    I used the C11G for my set up. Works great for me.
    Jun 2006
    13
    Find the best Mach3 breakout bord incl PWM analogue 0-10V output for VFD at www.cncdirect.co.za or www.leeuwinga.nl
  1. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  2. Which breakout board to use
    By erkiwi in forum Stepper Motors / Drives
    Last Post: 05-05-2007, 08:08 AM
  3. New breakout board
    By corydoras in forum CNC Machine Related Electronics
    Last Post: 04-26-2007, 12:23 AM
  4. What is a breakout board?
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 08-28-2005, 11:37 PM
  5. Parrallel Breakout suggestions
    By Bird_E in forum CNC Machine Related Electronics
    Last Post: 07-21-2005, 10:08 PM
