Hi Folks, I'm about to start building my servo box and want to get your opinion on connectors, fuses, wire size etc.
the system:
power supply - 1.5KVA, 170VDC, 9A
AC drives - 1kW, 12.5A
AC motors - 1kW, 11.7A, 100V
8 wire quadrature encoder
motor brake 24V
motor/encoder cable length 15ft
jog pendant cable length 15ft
Checklist will include:
1. encoder wire, connectors
2. motor wire, connectors
3. fuses on AC line, DC logic and drive power
4. pendant wiring & switches
5. limits & wiring
6. other
Here are my choices for encoder wire:
Belden 9538, 24AWG strand (7X32), 8 conductor
(aluminum-polyester shield with stranded tinned copper drain wire)
and encoder connectors:
Tyco AMP CPC type http://www.action-electronics.com/ampcpc.htm
I can't seem to come up with anything for motor power. What do you think about this one?
It's a 14AWG 4 conductor HOSA speaker wire with Speakon connector that locks into place via a latch-type lock, available at local stores for approx $50/25ft. Would this be enough for my servos?
Your help and comments will be appreciated.
_
