I have acquired a Logan Lathe model 922. I am fixing it up and have nearly completed it. The last issue is it came with an old 1 inch wide flat leather belt to power the headstock. I was hoping to swap out the two step pulleys with v-groove pulleys, but the bore on the headstock is too large, and I can't find a step pulley that would work.
So my option is to find a new belt. I looked on sdp-si, but couldn't find what I was looking for. I'm hoping the greater wisdom of the forum will point out my ignorance and I can finish this project.
I looked on McMaster for step pulleys, but the largest bore they had was .75". Anywhere else I should be looking?
Thanks in advance!
